probe settings
12pratham
Please let me know if i can change the probe settings to 40 sec instead of current values
probe tcp PROBE_HTTP
  port 161
  interval 3
  faildetect 2
  passdetect interval 3
  open 10
as the servers are responding to the probes by ACE LBs ,every sec   ,creating huge amount of log files on the server.
Let me know if I can change the probe values
Alex Rickard
Level 4
Level 4
Probe settings are configurable. To configure the frequency that the ACE sends the probe use the interval seconds comand. The seconds part of the command is the time interval that you would like to configure. Open, faildetect, passdetect items are also configurable. For details on health monitoring, see the server load balancing configuration guide. I have included the link for the A4(1.0) guide below.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_1_0/configuration/slb/guide/probe.html#wp1031139
