Problem CBWFQ not working on ATM interface
mark.tutton
Level 2
Level 2
I have applied CBWFQ config to 7200 router ATM pvc, but when I send 2 test files of 200Mbit from the LAN port over the ATM pvc, one from class LBE (lower than best effort using CS1) and one from class default, QoS is not working.
Looking at the stats using 'policy-map int atm 1/0.188 vc 100/192' the packets have been transmitted in class CS1 ok, but it also appears that no packets/bytes have been matched.
Please see my cut down config, showing the 2 classes, policy map and show commands.
Has anybody got any ideas what I have done wrong?
Would appreciate some help.
regards
mark
Gilles Dufour
Mark,
you're on the wrong forum for this type of questions.
Gilles.
