Problem when access to CSS with SSH
Daniel Lopez Ramirez
Community Member
We have an strange issue when we try to access to the management of the CSS with SSH protocol: we need to put the username twice.
Is it a normal behaviour?
login as: test
User Access Verification
Username:test
Password:
test# show version
Version:               sg0810106 (08.10.1.06)
Flash (Locked):        08.10.1.06
Flash (Operational):   08.10.1.06
Thanks.
Best regards,
Dani
Sean Merrow
Level 10
Level 10
Hello Dani,
This has been the behavior of the CSS when logging in via SSH since the product was introduced.  So yes, this is normal behavior for the CSS.
Hope this helps,
Sean
Sean Merrow
Level 10
Level 10
Hello Dani,
Hope this helps,
Sean
Hello Sean,
Thanks for your help.
Best regards,
Dani
Hello
Is there any way to avoid this "login as"?
I have problems to access this CSS from the CiscoWorks, I need other value moreover user / password.
Thank you.
