Problem with ACS Server
bcarnegie
Community Member
Good morning;
I hope this is the right forum so here it goes. I have an ACS server v4 that keep hanging. If I try to restart the server (CSAuth), the service hangs and the only thing I can do is restart the server. Is there something I can do to fix this or troubleshoot it better?
jreekers
Level 8
Level 8
Hi..are you running on a Windows server? If so, do you have any antiviris software installed? If you do, try disabling that and then see if the server still hangs.
tarv1s1umacelum
Community Member
Good morning,
I have the same problem with an ACS 3.3.3 that occasionally restarts CSAuth for a configured function to proceed, but the service keep hanging.
Have you find any solution?
I was told it was anti-virus so we stopped the anti-virus software and its still happening. Now we think the AV software might have corrupted the directories and files. We even put the directories as an exclusion.
