Problem with CSS11500, DNS and SSH.-
Francisco Aguilar Aravena
Community Member
Dears:
I have a problem with the CSS11503. I need to balance DNS servers for the requests of these reach a vip you distribute the load.
I use these links:
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801d015a.shtml
https://supportforums.cisco.com/message/459776#459776
With these I manage to load balance DNS level but I can not manage computers via SSH, could someone tell me this may be due to
Thank you very much.
Daniel Arrondo Ostiz
Hi Francisco,
If you configured the content rule to match only DNS traffic, SSH will just get routed through the CSS and therefore, it should not be impacted.
Can you please copy your configuration here? I will have a look at it to see if there are any mistakes.
Alternatively, you can open a TAC service request to have this issue investigated further.
Daniel
My config is:
circuit VLAN23
  description "Red-DNS_Servers"
  ip address Y
service dns_pruebas
  ip address X
  keepalive type script ap-kal-dns "X"
  active
OWNER
content DNS_PRUEBA
    vip address X
    add service dns_pruebas
    active
group DNS
  vip address X
  portmap disable
  active
Thanks for your help.
Hi Francisco,
I meant your full configuration, not just parts of it and without masking any of the configuration lines.
If you are concerned about privacy, then, it would probably better if you open a TAC service request to have this investigated further.
Daniel
