Problem with first boot Cisco WAE-674-k9
hcbankbelarus
At the first loading WAE-674-K9 on the monitor screen there are messages:
db_grub_start. S,
Decommpressing Linux... done, booting the kernal.
at the bottom there is Kernel alive and kernel direct mapping tables up to 140000000 800-e000
Thus further occurs nothing.
This error arises at the first boot WAE-674 without recovery disk.
Write please actions on steps to solve this problem.
Help to solve this problem please.
What credential for management cisco through the console? admin-admin, cisco-cisco do not satisfy.
ktunugun
After a certian point of boot the display gets re-directed to the console port and you wouldn't see anything on the Monitor. This is normal.
Please use console connection to connect to the device. The default credentials are admin/default
Hope this helps.
Kiran.
ktunugun
Hope this helps.
Kiran.
