Problem with rbackup-server
Dear Mister
I have the next configuration:
rserver host WWW-GEMINIS
ip address 10.100.5.26
probe PING
probe HTTP
inservice
rserver host WWW-NOVA
ip address 10.100.5.5
probe PING
probe HTTP
inservice
serverfarm host WWW
rserver WWW-GEMINIS
backup-rserver WWW-NOVA
inservice
rserver WWW-NOVA
inservice standby
The ides is that when the WWW-GEMINIS is down, jump to the server WWW-NOVA. This is functioning. The problem is in when WWW-GEMINIS come back to up, WWW-NOVA still is receiving connections. WWW-NOVA remains in balancing, but the ral state is standby??
Which is my error???
Does exist another solutions???
Best Regards
dario.didio
Level 9
Level 9
Are you using stickyness?
That would be the only reason it still receives connections, because for me the config looks good.
Yes, iam looking the rest of configuration.
I must to disable that ???
Plly disable the policy regarding stick ???
Best regards and lot of thanks.
If you don't need the stickiness for any other reason and if NOVA is really just a backup for GEMINIS You could define two serverfarms with one rserver in each.
serverfarm host WWW-Primary
rserver WWW-GEMINIS
inservice
serverfarm host WWW-Backup
rserver WWW-NOVA
inservice
With only one server in each farm you don't need stickiness and then your loadbalance policy can look like:
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm WWW-Primary backup WWW-Backup
Cathy
