Problem with SNAT UDP
ingredosi
Community Member
I,ve been trying to run CSS11500 07.40.2.02 one-armed DNAT+SNAT with RTP udp 10000-30000.
I need to nat client ip addresses.
service serv1
ip add 90.1.1.1
protocol udp
active
owner
vip add 10.1.1.1
protocol udp
add serv serv1
active
group
vip add 81.1.1.1
portmap disable
add destination service serv1
active
DNAT and SNAT is OK:
IP client > CSS: 10.x.x.x:10000 > VIP 10.1.1.1:20000
IP SNAT> internet: SNAT 81.1.11:10000 > 90.1.1.1:20000
but the response:
Internet> CSS: 90.1.1.1:20000 >81.1.1.1:10000
is dropped in CSS (verified)
whithout "portmap disable", works, but the source port of client is natted...
I´d appreciate any suggestions about this problem.
Gilles Dufour
The combination of 'portmap disable' and client-source-nating is not supported.
The reason is that if you disable portmapping, when 2 clients hit the vip with the same source port, the traffic is sent to the server with the same source ip and port. It is therefore not possible for the CSS to identify the client ip when the response from the server comes back.
So do not use one-armed mode or make the CSS the default gateway for the servers.
Gilles.
