Problem with SSL on ACE
cisco_lite
Level 6
Level 6
The self-signed certificate on ACE was working perfectly fine. I removed it for some reason. And then put it back after few days. Now the https is not working.
On Firefox, following error is returned
SSL received a record that exceeded the maximum permissible length.
ssl_error_rx_record_too_long
And on Ethereal (both IE and FireFox), I can see 'SSL Continuation Data' sent back by the ACE with HTTP/1.1 400 Bad Request message saying the request contains invalid syntax.
Please assist. Thank you.
Gilles Dufour
There is a known defect that was fixed in A2(1.3) and A3(2.1)
CSCsu74351: SSL Client Sends Bad Record MAC fatal alert due to TCP .
Description:
Sometimes Firefox reports ssl_error_bad_mac_read or ssl_error_rx_record_too_long and partially loads a page. Internet Explorer will also fail to load the page but will not report the error.
Gilles.
The issue is resolved. Wrong configuration.
