Problems with acns 5.2
lanrey_tnk
Community Member
I have several regional offices connected through wan to central office.
Configuration: 2*7206 with wccp v2 and CE565 and CE560 (CEs clustered).
Http traffic from regions thorough wan redirects to ce.. It worked perfectly with acns 5.1.3.15 until i have upgraded ce to acns 5.2.3.9 (acns 5.2.1.7 also)
The problem is that wccp is not working when replies from CE's are routed through wan (serial interfaces).
And it works when replies are routed through ethernet. (It works so in the central office).
Not applicable
Looks like you are running into the known issue CSCdw64186.
markedwards
Community Member
Not sure but this bug ID is to visible (Cisco Restricted?)
Not sure why this bug id was referenced -- the bug has nothing to do with the problem originally posted.
Have you having similar problems as the original post?
~Zach
