problems with Arrowpoint Cookies
STEVE FLIS
I have a CSS 11503 set up in a DMZ that is load balancing 2 Netsilica proxies. All worked ok when I used Sticky Scrcip.
We are also using Akamai externally, they said clients ip may change during use. Tried to use arrowpoint cookies.
service
strig xyz
content rule
balance aca
advance balance arrowpoint-cookie
arrowpoint-cookie expiration 01:00:01:01
this seems to bounce the users from proxy to proxy.
Need sticky non source IP , any ideas welcome
Steve
Gilles Dufour
Steve,
first, if you can't use sourceip for stickyness there is no other solution than cookie.
Arrowpoint cookie should work.
Veriy with a sniffer trace if the client is sending the cookie with each request.
Some browser disable cookies.
Gilles.
