Problems with CS11000 (Arrowpoint CS-800)
ggiusti
Community Member
Hi all,
In a moment (without reason) Load Balancer see all services suspend and then down.
When reboot this, all come back OK.
Version: ap0610405 (6.10 Build 405)
Flash (Locked): 3.10 Build 46
Flash (Operational): 6.10 Build 405
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
The are 11000 Flows
CPU 40%
Memory on SFM 128MB
Please could you help me...?
I don´t know whats happend.
5 Replies 5
Gilles Dufour
if you rebooted the CSS then it is too late to help you. [unless the problem is still there].
Next time, capture 'script play show_tech' and a sniffer trace of the keepalive traffic.
Try to see if different type of keepalive work and if you can ping the servers from the CSS.
Gilles.
Gilles,
I don´t know if different keepalive work, just I try to make a ping to web servers and working fine.
The scenario is that I have 3 content balancing web server and 3 content balancing NetCache but when add the 4th, after many hours appears the problem that I mentioned.
Regards.-
ggiusti
Community Member
Gilles,
Recently its happen again. I send to you the script of show_tech.
I see that error:
FLOWMGR-6: <010> FM_Tcp: Handling generic FMTCP flow Re-Transmit ERROR
Regards.-
ggiusti
Community Member
Hi Guilles,
Could you see the "showtech"...? What do you think..?
Thanks for your help.
Guillermo
Guillermo,
I checked the show tech and there is no info there indicating a problem except a huge number of servers down.
Could you capture a sniffer trace between the CSS and some servers to see what is going on.
Try to capture on a switch adjacent to the CSS.
Gilles.
