Query on optimization issue.
tayyappa
Community Member
Consider the senario, We have two WAE registered to a CM.
The optimization of the entire system is not good. Need to check which WAE is not optimizing good?
Zach Seils
Level 11
Level 11
By "not good" do you mean that the connections aren't being optimized?  Or is it that the end user performance is worse?
Zach
The connections aren't being optimized in my case.
If you issue the command sh stat conn, what is the ConnType for the pass-through connections?
Zach
