Question Cisco ACE mode bridge - client side connect to servers
I have configured the cisco ace 4710 in mode bridge, but i want know if i can connect servers of the vlan 401 in the Switch, for example 10.1.40.50 with default-gateway SVI 401 10.1.40.10 with real servers of the ACE (10.1.40.2 and 10.1.40.3 with default-gateway bvi 10.1.40.1)
**********************************Cisco ACE**********************************
ace-demo/Admin# sh run
Generating configuration....
boot system image:c4710ace-mz.A3_2_4.bin
boot system image:c4710ace-mz.A3_2_1.bin
hostname ace-demo
interface gigabitEthernet 1/1
  channel-group 1
  no shutdown
interface gigabitEthernet 1/2
  channel-group 1
  no shutdown
interface gigabitEthernet 1/3
  channel-group 1
  no shutdown
interface gigabitEthernet 1/4
  channel-group 1
  no shutdown
interface port-channel 1
  switchport trunk allowed vlan 400-401,450
  no shutdown
access-list bpdufilter ethertype permit bpdu
access-list anyone line 8 extended permit ip any any
access-list anyone line 16 extended permit icmp any any
rserver host rsrv1
  ip address 10.1.40.2
  inservice
rserver host rsrv2
  ip address 10.1.40.3
  inservice
serverfarm host farm-demo
  rserver rsrv1
    inservice
  rserver rsrv2
    inservice
class-map type management match-any MGMT
  2 match protocol icmp any
  3 match protocol http any
  4 match protocol https any
  5 match protocol snmp any
  6 match protocol telnet any
  7 match protocol ssh any
class-map match-any VIP
  3 match virtual-address 10.1.40.20 any
class-map type management match-any icmp
class-map type http loadbalance match-any p-site-A
policy-map type management first-match ICMP
  class icmp
    permit
policy-map type management first-match MGMT
  class MGMT
    permit
policy-map type loadbalance first-match server-balance
  class class-default
    serverfarm farm-demo
policy-map multi-match client-side
  class VIP
    loadbalance vip inservice
    loadbalance policy server-balance
interface vlan 400
  description side-server
  bridge-group 1
  access-group input bpdufilter
  access-group input anyone
  service-policy input ICMP
  no shutdown
interface vlan 401
  description side-client
  bridge-group 1
  service-policy input client-side
  no shutdown
interface vlan 450
  description mgmt
  ip address 10.1.45.1 255.255.255.0
  service-policy input MGMT
  no shutdown
interface bvi 1
  ip address 10.1.40.1 255.255.255.0
  no shutdown
ip route 192.168.10.0 255.255.255.0 10.1.45.10
**********************************Switch**********************************
vlan 401
name client_side
interface vlan 401
ip address 10.1.40.10 255.255.255.0
no shutdown
ohynderi
Technically yes you can. A couple of questions:
- Will 10.1.40.50 be part of a serverfarm on ACE (with other rserver on vlan 400)
- Why gateway on 10.1.40.2 and 10.1.40.3 needs to be the ACE BVI IP and not 10.1.40.10?
Olivier
Hello olivier,
- 10.1.40.50 is not part of serverfarm on ACE (vlan 401)
- The gateway can be 10.1.40.10 in vlan 401? the rserver on vlan 400.is it posoble?
Hello agin!
So in bridge mode, with below topology, servers should have their gateway pointing to the router ip.
Router -- vl401 -- ACE -- vl400 -- Servers
So in your case, server on vlan 400 should have their default route pointing to 10.1.40.10.
--Olivier
