Redirect Problem with ACE 4710 !
dominik.menzi
Community Member
Greetings
I must  redirect all connections from port 443 to 9443.
this is configered and running:
serverfarm host FARM-002
  probe test-xml
  rserver svx-xmlfw-lb-01 9443
    backup-rserver svx-xmlfw-lb-02 9443
    inservice
    inservice standby
serverfarm host FARM-003
  rserver svx-xmlfw-lb-03 9443
    inservice
I have in the moment following problem. All connections become redirectet to port 9443 but port 8080 shouldn`t be redirectet to port 9443. What can i change in my config to solve this problem?
Thanks for help
Dominik
6 Replies 6
sivaksiv
Hi Domnik,
One option is to configure a virtual ip for port 8080 and make them not to be reciredted anywhere.
Siva
Thanks for the answer
What do mean with e virtuel ip for port 8080?
Current configuration is:
    inservice
sticky ip-netmask 255.255.255.255 address source STICKY-GRP-003
  timeout 1
  serverfarm FARM-003
class-map match-all VIP-003
  2 match virtual-address 193.134.75.9 any
policy-map type loadbalance first-match LB-POLICY-003
  class class-default
    sticky-serverfarm STICKY-GRP-003
policy-map multi-match LB-TRAFFIC-001
  class VIP-003
    loadbalance vip inservice
    loadbalance policy LB-POLICY-003
    loadbalance vip icmp-reply active
  timeout 1
  serverfarm FARM-003
This VIP 193.134.75.9 has the DNS webservices.baloise.ch. Do you mean e second VIP with another Hostname?
Dominik
Hi Domnik,
Add another VIP as below.
class-map match-all VIP-8080
  2 match virtual-address 193.134.75.9 tcp eq 8080
  class VIP-8080
  class VIP-003
Siva
Hi Siva
Thank you for you reply
We tried it in three ways:
First way
    inservice
class-map match-all VIP-003-8080
class VIP-003
class VIP-003-8080
  2 match virtual-address 193.134.75.9 tcp eq 9443
    inservice
doesn`t work , it works only the redirection 9443
second way
    inservice
class VIP-003
class VIP-003-8080
third way
inservice
class VIP-003
class VIP-003-8080
doesn`t work , it works only the redirection 8080
Do you see where we made a mistake
Dominik
Hi Dominik,
VIP-8080 should be applied first followed by other VIP.
I created a new serverfarm for VIP 8080 so it gets redirected on the same port.
serverfarm host FARM-8080
  rserver svx-xmlfw-lb-03 8080
    inservice
class VIP-003-8080
loadbalance policy LB-POLICY-8080
class VIP-003
Siva
Thanks e lot!
I check this monday morning. Have e nice weekend!!
Dominik
