Rejected Connection Counts Due To Connection Limit
Hi there,
using the command below, I can see the Rejected Connection Counts Due To Connection Limit.
Is this count based on remote-office TFO limit ? How can I be sure if this connection limis a problem in the WAAS core or in the remote-office ?
I need to know if I should upgrade the core or the remote-office
remote-office#show statistics tfo detail
Connection Limit    :     531844
Thanks.
Andrei.
jlamousn
Hello Andrei,
The problem would be on whatever waas device you are getting the output on.  You can further run "show tfo det" to see the tfo effective connection limit for your waas hardware and compare that with the current active optimized flows in the "show stat conn" output.
Joel Lamousnery
CCIE R&S - 36768
Engineer, Customer Support
Technical Services
Joel Lamousnery CCIE R&S - 36768 Engineer, Customer Support Technical Services
