Required help on GSS setup in datacenter
sateeshk10
hi,
I have two GSS, now i would install one GSS at one location and other i will keep in secondary.. my requiremnet is first GSS fails..then second GSS which is located other datacenter shld take care..
GSS1 --- DC1
GSS2 ---- DC2
1) I am configureing GSS1 as primary and GSS2 is a secondary is it right??
DNS:
xyz.abc.com NS PRIMARY GSS IP
xyz.abc.com NS SEC GSS IP
is it right?
GSS config
Two answer groups gcreated one for pri and sec..
i have given wei 10 for pri and 1 for secodary... it is right??
weighted round robin method enabled
keepalive:
i have ocnfigured KAL-AP for both the VIP...
At the time of cration its asking pri and sec..i have given only primary..
For secGSS i am going to create one KAL-AP is it ok..???
Thanks in advance..
sateesh
sateeshk10
Wating for your reply..pls do the needful..its very urgent..
sateesh
