response time https/http using CSM+SSL versus CSM
v.kreisel
Community Member
Im using C6K and CSM for load balancing and an SSL module for https termination. That means clients can access the serverfarm through https/http and compare response time values.
What should be the expected delay generated from SSL(https) compared to cleartext(http) ?
My customers are complaining about to much delay...
Thanks in advance for your answer.
Volker
Gilles Dufour
it's difficult to answer.
There will be an initial delay required to establish the ssl session, then for each packet there will be additional delay to encrypt/decrypt the packet.
It also depends on load.
An CSM can handle lot of traffic but not an SSLM.
So, if you see something wrong in a sniffer trace like packet drops, retransmits, huge delays per packet [like 300ms], then we need to investigate what is going on.
Otherwise, this would be normal.
Gilles.
