RTP/RTCP stream load balancing with CSS
Branimir Turk
Level 3
Level 3
Is there any way to load balance RTP/RTCP streams with css?
Diego Vargas
The CSS is able to balance the traffic at layer 4 (just looking at the ports), so there should be no problem.
The trick is to give the correct TCP port numbers.
About RTP/RTCP, I am not familiar with the protocol, but if it works with TCP, then here again, the correct port numbers should work.
Hope it helps!!
I agree about TCP, but it seems that RTP is using dynamicly assigned ports.
If the ports are not always the same you can have the CSS configured with a layer 3 rule (listening for any TCP port).
Tnx for the info.
