Same content rule for port 80 and 443
rlortiz
I have a site that needs to have 1 content rule for both port 80 and port 443. Presently, we are using more than one server for both rules. Is there a way to setup one content rule for 2 ports? The reason behind this is the desire to have both port 80 and port 443 use the same server.
Here is the example config using 2 rules with more than 1 server, but would rather have one rule:
owner Trixone
content trixone-bst-443
protocol tcp
port 443
vip address xx.xx.xx.xx
add service fdevap1-8251
add service fdevap2-8251
balance aca
arrowpoint-cookie path "/"
sticky-inact-timeout 120
no persistent
application ssl
advanced-balance ssl
active
content trixone-bst-80
protocol tcp
port 80
add service fdevap1-8250
add service fdevap2-8250
balance aca
advanced-balance arrowpoint-cookie
no persistent
active
content trixone-bst-w-443
protocol tcp
port 443
add service fdevap1-7253
add service fdevap1-7255
add service fdevap1-7257
add service fdevap1-7259
add service fdevap2-7253
add service fdevap2-7255
add service fdevap2-7257
add service fdevap2-7259
balance aca
application ssl
no persistent
active
content trixone-bst-w-80
protocol tcp
port 80
add service fdevap1-7252
add service fdevap1-7254
add service fdevap1-7256
add service fdevap1-7258
add service fdevap2-7252
add service fdevap2-7254
add service fdevap2-7256
add service fdevap2-7258
balance aca
no persistent
active
Gilles Dufour
replace the existing rules with one that does not specify the port [L3 rule].
However, you can't use arrowpoint cookie anymore.
And you can't use 'advanced-balance ssl'.
Another solution would be to use an SSL offloader to decrypt the traffic and have the cookie inserted in the https traffic as well.
Gilles.
