Same probe for multiple serverfarm ?
m.baker
Is there any problem using the same probe for multiple serverfarm ? If I use the same probe for multiple server farm, does the CSM then use the probe counters/per serverfarm.....or per probe ?
seilsz
Level 8
Level 8
Yes, you can use the same probe for multiple serverfarms. Regarding your second question, which probe counters are you referring to?
~Zach
Zach
By counter I meant the internal counter the CSM uses to track the number of failures for the probes...
The counter would be specific to the server(s).
~Zach
