SAP application disconnection issue
vijayarampm
Spoke location users are facing frequent SAP application disconnection issues. SAP servers are hosted in Data center. Please find the below logs from location Cisco router logs for your reference.
Mar 6 11:59:22.235: %LINK-3-UPDOWN: Interface Serial0/1/1, changed state to up
Mar 6 11:59:56.240: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/1, changed state to up
Mar 6 11:59:56.744: %BGP-5-ADJCHANGE: neighbor 172.17.48.82 Up
Mar 6 12:00:45.735: %LINK-3-UPDOWN: Interface Serial0/1/1, changed state to down
Mar 6 12:00:45.743: %BGP-5-ADJCHANGE: neighbor 172.17.48.82 Down Interface flap
Mar 6 12:00:46.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/1, changed state to down
Mar 6 12:01:25.244: %LINK-3-UPDOWN: Interface Serial0/1/1, changed state to up
Mar 6 12:01:56.313: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/1, changed state to up
Mar 6 12:01:56.921: %BGP-5-ADJCHANGE: neighbor 172.17.48.82 Up
What will be the cause for this issue and provide us the solution for permanent fix.
Vijay.
You should probably install SAPRouter (see http://service.sap.com/saprouter). It redirects incoming SAPGUI connections to the correct SAP systems. It has many connection and security configuration settings (see the online documentation for more information). SAPRouter listens by default to port 3299. You will have to open this port on your firewall.
