sca+css 11000 outbound routing+access list problem
devrim.kalmaz
http://www.cisco.com/en/US/products/hw/contnetw/ps2083/products_configuration_example09186a00801bbf4e.shtml
We a have a configuration like in this link.But our vlan2 servers (ex.10.2.2.3) have some files or gadgets which run/get from servers in vlan1/intranet/our_lan (ex.10.50.50.x).In this case our gadgedts and linked files didn't run well.So we add manuel routing to this gadget running servers to solve our problem.(ex route add 10.50.50.x to upstream-router )But now we have another small problem.The problem is that our intranet servers which is on vlan1 side (10.50.50.x) cannot reach https services on vlan2 servers (ex.10.2.2.3).The configuration is work for other users very well.Thanks,
8 Replies 8
devrim.kalmaz
sample drawing attached.
Devrim,
we will need your config and information about source ip and destination ip having problem to communicate.
Is it all the time, sometimes ?
Is it all type of traffic or just http or just https or .. ?
Gilles.
It's all the times.
It's only http and https.
Has anyone got any idea?Thanks,
you need to remove your extra static routes.
You're breaking the ecmp concept.
To solve your gadget problem, you need to use acl prefer.
something like
clause 5 permit any any destination 10.50.50.10 255.255.255.0 prefer upstream-router
Apply this on you servers vlan.
Also your ACL 10 will need a clause 99 permit any any destination any.
Give it a try like this and let me know what works and what does not.
Gilles.
is this the right config?
acl 5
clause 10 permit any any destination any
apply circuit-(VLAN1)
apply circuit-(VLAN2)
acl 10
clause 5 permit any any destination 10.50.x.x 255.255.255.0 prefer upstream-router
clause 10 permit any any destination any prefer upstream-router
apply circuit-(VLAN3)
Looks good.
I assume your servers are in vlan 3.
Does it work ?
G.
Yes our https servers are in vlan3.
Gadget servers are in vlan1.
I can try it tomorrow.I'll write results here.
Thank you.
