SCA Performance Issues
david-henderson
Community Member
Recent datacentre design uses both CSS Content Switches and SCA SSL accelerators. Services working fine, however SSL acceleration actually SLOWS DOWN during the day. Up to four minutes to load a SSL encrypted page in the afternoon as opposed to a morning check.
Cached sesion data is our best guess. Caching is turned on by default on the SCA boxes. Can't find any documentation on turning it off. Would like to try and run boxes with caching turned off, if only to discount as a possible cause of performance probems.
Need urgent help please, as datacentre is going live extremely soon. Any ideas, thoughts etc welcome.
David.
ciscomoderator
Administrator
Administrator
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac)
Since you specified your issue is urgent, you should open a case with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
