SCA Transparent Mode
m-hennigan
Community Member
At a customer site any traffic running from the SCA through their CSS shows the SCA as the source IP in the server logs. I need to be able to set this up so the customer can see the real source address from their clients. I followed the docs on how to do one armed transparent mode but I obviously missed something or did something incorrectly. Attached are the configs.
Gilles Dufour
could you tell us what's wrong.
Is it still using its own ip or you have no connectivity ?
The CSS config is also very important.
Did you configure correctly the default gateways ?
[one pointing at the SCA and one to the router].
Is the default gateway of the server set to the CSS ?
If you can't make it work, use a sniffer trace to understand the traffic flow.
For reference, here is a link to the config
http://www.cisco.com/en/US/products/hw/contnetw/ps2083/products_configuration_example09186a00801bbf4e.shtml
Gilles.
We are still receiving the address of the SCA as the source address when looking at the logs for the sites, we need to see the actual client address. The configs are attached to my post. The server default gateway is not set to the CSS as this is not an option in their current enviorenment but they are on the same network. There is only a single default gateway, the SCA is on the same network as the outside interface of the CSS.
