Cisco 11500 transmission between two server pools
bapayne
I have two server pools and one pool needs to periodically update the other, and both need to face the world. Both face the world just fine. When the .47 tries to update the .48 the packets are dropped by the css.
Here is the switch config:
CSS11503# sho run
!Generated on 09/07/2004 08:54:41
!Active version: sg0710102
configure
!*************************** GLOBAL ***************************
logging host X.Y.4.254 facility 4 log-level 7
ip route 0.0.0.0 0.0.0.0 X.Y.36.1 1
!************************** CIRCUIT **************************
circuit VLAN1
ip address X.Y.36.9 255.255.255.0
!************************** SERVICE **************************
service PLAB1
ip address X.Y.36.233
keepalive frequency 10
active
service PLAB10
ip address X.Y.36.243
active
service PLAB11
ip address X.Y.36.244
active
service PLAB12
ip address X.Y.36.245
active
service PLAB13
ip address X.Y.36.246
active
service PLAB14
ip address X.Y.36.247
active
service PLAB2
ip address X.Y.36.234
active
service PLAB3
ip address X.Y.36.235
active
service PLAB4
ip address X.Y.36.236
active
service PLAB5
ip address X.Y.36.237
active
service PLAB6
ip address X.Y.36.238
active
service PLAB7
ip address X.Y.36.239
active
service PLAB8
ip address X.Y.36.240
active
service PLAB9
ip address X.Y.36.242
active
!*************************** OWNER ***************************
owner NES
content Load7
add service PLAB1
add service PLAB2
add service PLAB3
add service PLAB4
add service PLAB5
add service PLAB6
add service PLAB7
add service PLAB8
balance aca
vip address X.Y.36.47
active
content Load8
add service PLAB9
add service PLAB10
add service PLAB11
add service PLAB12
add service PLAB13
add service PLAB14
balance aca
vip address X.Y.36.48
active
CSS11503#
I believe that the switch is filtering traffic going from one pool to the other. If I send traffic from one pool to the specific IP addresses of the servers in the other pool it works.
jfoerster
Level 4
Level 4
if you do not have configured client NAT for connection between servers within Content Load 7 to update content load8 the connection will break because the return flow will not hit the CSS. Therefore the CSS detects this flow as a DoS and drops it. Just configure some client nat using ACLs or destination services and it should work Btw how do you ensure that every server is updated because if you trigger it from one server within Pool7 the CSS will choose on of the server and than the update will run on this one. If you there is no mechanism that the next update points towards another server you have the possibilty to update all of them, but this is another story.
Kind regards,
Joerg
