second ethernet interface ni a cache engine
foliveri
Community Member
I'm trying to configure the second ethernet interface
in a CE 505, version 2.51
a "show hardware" command shows 2 ethernet interfaces, but when I go into configuration
mode and try to set any parameter in the second
interface, I get the error:
"configure interface 1 denied"
Thanks for any clue.
madittmer
Community Member
On a CE-505 you cannot use the second interface. This is a limitaion of the software on the device. Only if you had a content engine running version 3.x or 4.x can you use the second interface.
Best Regards,
Mark
