show ip slb stats?
henrik.stryhn
What does all this mean? I'm particularly in the entries which indicates errors:
I looks like a serious problem, with over 100.000 failed connections, in only 700.000 created connections.
Connections Created:        692177
Connections Destroyed:      591523
Connections Current:        100654
Connections Timed-Out:      21192
Connections Failed:         115898
Server initiated Connections:
      Created: 0, Current: 0, Failed: 0
L4 Load-Balanced Decisions: 693066
L4 Rejected Connections:    0
L7 Load-Balanced Decisions: 0
L7 Rejected Connections:
      Total: 0, Parser: 0,
      Reached max parse len: 0, Cookie out of mem: 0,
      Cfg version mismatch: 0, Bad SSL2 format: 0
L4/L7 Rejected Connections:
      No policy: 0, No policy match 0,
      No real: 0, ACL denied 0,
     Server initiated: 0
Checksum Failures:  IP: 0, TCP: 0
Redirect Connections: 0,  Redirect Dropped: 0
FTP/RTSP Connections:            0
MAC Frames:
      Tx: Unicast: 78312749, Multicast: 1455988, Broadcast: 1240,
          Underflow Errors: 0
      Rx: Unicast: 78272614, Multicast: 3911, Broadcast: 1237,
          Overflow Errors: 900, CRC Errors: 0
Best Regards
Henrik Stryhn, Denmark
jny
“The number of TCP and UDP connections destroyed by SLB, either by TCPIP teardown or timeout. UDP connections can only be timed out."
                      “UDP connections destroyed as result of timeout”
/nykaer
