02-19-2006 01:19 AM
Has anyone tried using smartfilter 4.1 with ACNS 5.1 on content engine 565.
ACNS 5.1 is running.
SmartFilter API Version: 3.2.4
SmartFilter Plugin Version: 3.2.1.00
I tried using port no. 8001 and 8003. But smartfilter administration console shows "agent not Responding". URL-FiLTER smartfilter is enabled on content engine and logs show the plug-in getting active.
Please suggest what am I missing.
Thank you.
Solved! Go to Solution.
02-19-2006 02:33 PM
Pankaj,
Support for version 4.1 of SmartFilter was added in ACNS version 5.4. Version 5.1 only supports SmartFilter version 3.2.
~Zach
02-19-2006 02:33 PM
Pankaj,
~Zach
02-19-2006 09:14 PM
Thank you. That did the trick.
