snmp on CE 2636 module
johcox
I'm using the CISCO-CONTENT-ENGINE-MIB to get mrtg stats from CE565s. I cannnot see anywhere that it should not also work on the 2636 CE modules as both run the same version of ACNS, but it does not seem to.
Anyone tried this successfully with the 2636 module?
-Julianne
pradeepde
Level 5
Level 5
The ACNS 5.x software implementation of SNMP supports the following MIBs:
MIB-II
ENTITY-MIB
HOST-RESOURCES-MIB
CISCO-ENTITY-ASSET-MIB
CISCO-CONFIG-MAN-MIB
CISCO-CDP-MIB
Could you please refer the link below which has more details about the CISCO-CONTENT-ENGINE-MIB
http://www.cisco.com/en/US/products/sw/conntsw/ps491/products_configuration_guide_chapter09186a0080236630.html
So, you are saying that it should work for the 2636 modules as they are running ACNS? This was what I assumed too, but with the same snmp config that works successfully on the 565s, I can't get a response from the module.
