sntp problem
julxu
Level 7
Level 7
the configuration looks simple, but I just can not make it work? Could anyone help me?
configuration:
sntp server 10.10.1.1 version 3
ip management route 10.10.1.1 255.255.255.255 10.3.1.2
CSS11506# sh sntp global
SNTP Global Summary:
Server Address: 10.10.1.1
Version: 3
Poll Interval: 64
TimeSinceLastUpdate: 186661
Server status: DOWN
CSS11506# sh ver
Version: sg0740103 (07.40.1.03)
Flash (Locked): 07.20.2.06
Flash (Operational): 07.40.1.03
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Any comments will be appreciated
Thanks in advance
julxu
Gilles Dufour
julxu,
read the note in the following config guide
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080409805.html#wp1160987
"When using static routes for managing the CSS from subnets beyond the management LAN, the Ethernet management port supports the management applications listed in the "Configuring the Ethernet Management Port" section except CDP, DNS, SNTP, and TACACs."
In other words, you can't route SNTP traffic out of the management port.
Gilles.
Thanks for rating
Gilles Dufour
julxu,
Gilles.
Thanks for rating
attendasecure
Frequent Visitor
Frequent Visitor
I have had this same problem. Try manually updating the local clock first to the current time
clock date
clock time
I did this and my ntp server then appeared as up.
Hope it helps.
your problem was because sntp can only adjust the time by a few minutes [or hours], so if the clock is too far away it does not work.
Howvever this is not the point here.
In this case, the problem is that sntp can't be sent out of the management port to a sntp server that would be behind a gateway as mentioned in the config guide.
Gilles.
