SOAP Load Balancing
gbbromley
Level 2
Level 2
Is anyone using CSMs to load balance traffic based on SOAP envelope values to maintain session affinity?
Is it possible to feed the inspected value into a cookie/element that can be used in a sticky group? (I'm guessing insert header could help?)
mchin345
Level 11
Level 11
Is is possible to load balance traffic based on SOAP using CSM's. But there is one thing which has to be taken care of.. Turn PMTUD off, in that case packets will get fragmented at upstream router and get sent to the client.
