SSL and Https Redirection
gopi_sivam
Community Member
HI all ,
1 )  I  Received a requirement as to perform the https to https redirection and do the ssl   installation in   CSS load balancer . Redirection need to happen from https://www.abc.com to https://www.abc.com/fcbd . i have a confusion in , how to add the /fcbd in the client request and send it to the backend  server .
  2 )        SSL cert is already installed  on the server for the above said domain , CSS can't add the string in the client header without decrypt the packets from client  , so i need to install the ssl cert also in CSS  . In this scenario ssl cert is installed on both server and CSS ( like END TO END in ACE ) , but I'm not familiar with css ssl  Configuration . Need to now ,  how to configure this type of SSL installation In CSS .
Regards , Gopinath
Plinio Brandao
Level 3
Level 3
Hi GOPINATH V,
What's the version of your CSS?
About SSL, do you want to do termination, initialization or end-to-end?
