SSL termination on ACE for Management purpose
subingsam
Can anybody let me know the steps / Commands to terminate SSL certifcate and key for ACE management purpose. It will help me to access the ACE box through explorer using https.
sachinga.hcl
Level 4
Level 4
Hi Subin,
You can use Cisco Application Networking Manager 4.1 for accessing/managing/adminstering ACE through web browser using https.
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5719/ps6904/product_bulletin_c25_622538.html
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5719/ps6904/product_bulletin_c25-572614.html
Use the following links for installation:
http://www.cisco.com/en/US/products/ps6904/prod_installation_guides_list.html
End-User Guides
http://www.cisco.com/en/US/products/ps6904/products_user_guide_list.html
User Guide for the Cisco Application Networking Manager 4.1
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/application_networking_manager/4.1/user/guide/User_Guide.html
The following steps are needed to configure SSL termination on the Cisco ACE:
1. Generate or import the key.
The syntax to generate the key on the Cisco ACE follows:
crypto generate key 1024
Example: crypto generate key 1024 testkey
The syntax to import the key to the Cisco ACE follows:
crypto import [non-exportable] [ ftp | sftp | tftp | terminal] [passphrase:passphrase] [ipaddr] [username] [password] [remote_filename] [local_filename]
2. Then Generate the certificate sign request (CSR).
The CSR can either be generated externally or on the Cisco ACE.
The following are sample steps that show how to generate CSR on the Cisco ACE:
Configure CSR parameters on the Cisco ACE:
crypto csr-params test123
  country US
  state CA
  organization-unit IT
  common-name aceapp.ccc.com
  serial-number 1000
  email user@ccc.com
3. Generate CSR using key and CSR parameters:
crypto generate csr test123 testkey
-----BEGIN CERTIFICATE REQUEST-----
MIIBnTCCAQYCAQAwXTELMAkGA1UEBhMCVVMxCzAJBgNVBAgTAkNBMQswCQYDVQQLEwJJVDEXMBUGA1UEAxMOYWNlY
XBwLmNjYy5jb20xGzAZBgkqhkiG9w0BCQEWDHVzZXJAY2NjLmNvbTCBnzANBgkqhkiG9w0BAQEFAAOBjQAwgYkCgY
EA1eaM318pX10/G8FYpi0cBRHdZA1Lxd9Q1vz2/nedQnNOkt0ZWQogH1Zgd5sxLHlPtn5afADhXmVreoY3c+s7TSG
vMLLXTIKxTbcURlw/0Y6CGpI/e3ASUBeLtMg7LE2C1EG6ZUL9HJyhUrZNXwOBXFAFL9DwrEx9CQJTmnKzj/8CAwEA
AaAAMA0GCSqGSIb3DQEBBAUAA4GBAJbKwzS/vuKhiu+PvEySUzCCHclA+x4KiON26txzKyog7YF7D0ZMKMcQjxrKW
ZRWtQgZPjv43Yzwqz4L8w8PyGsmBl7EYi7bOHQjcoKitfL4LJ9Qro8tf/tdn5DC1rGd3BP4XQ9SlxNBgHxzlzFS2f
WI/ynCmv5rbMtG+f/LHyKA
-----END CERTIFICATE REQUEST-----
3. Now Transfer the CSR request to Certificate Authority (CA) for signing
4. Load the CA signed certificate on the Cisco ACE
The syntax to import the certificate to the Cisco ACE follows:
5. If needed, chain the certificates using a chain group:
The chain consists of the certificates in the chain group, plus the configured certificate.
crypto chaingroup CCCSSLCA-group
  cert CCCSSLCA.PEM
  cert DSTROOTCA.PEM
cert ACEAPP-CERT.PEM
6. Configure the SSL parameter map, which is used to define parameters for SSL connections:
parameter-map type ssl PARAMMAP_SSL
cipher RSA_WITH_AES_128_CBC_SHA priority 2
7. Configure SSL proxy service:
ssl-proxy service PSERVICE_SERVER
  key ACEKEY.PEM
  cert ACEIDM-CERT.PEM
  chaingroup CISCOSSLCA-group
  ssl advanced-options PARAMMAP_SSL
Note: When you are creating a certificate signing request (CSR) at the ACE CLI using the csr-generate command, you cannot use the space character in the State value. Workaround: Use the state abbreviation.
Like here in the example California is said by abbrevation CA. So use similar types for states only one word withour space.
Kindly find below mentioned URL for your further information :
1.
http://docwiki.cisco.com/wiki/SSL_Termination_on_the_Cisco_Application_Control_Engine_Without_an_Existing_Chained_Certificate_and_Key_in_Routed_Mode_Configuration_Example
2.
http://docwiki.cisco.com/wiki/SSL_Termination_on_the_Cisco_Application_Control_Engine_Without_an_Existing_Chained_Certificate_and_Key_in_One_Arm_Mode_Configuration_Example
3.
http://cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/ssl/guide/certkeys.html
4. Command line : CSR Parameters Configuration Mode Commands
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/command/reference/csrparam.html
5.
Configure ACE with SSL Termination and URL Rewrite
http://docwiki.cisco.com/wiki/Category:Data_Center_Application_Services_Configuration_Examples
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3045.shtml
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Configuration_Examples
http://www.cisco.com/en/US/products/hw/modules/ps2706/prod_configuration_examples_list.html
Kindly rate if find useful.
Sachin Garg
