Standby GSSM refuse ssh connection
sokarlsson
Level 3
Level 3
I have 2 GSS-4492R just setup one as primary gssm and the other as standby-gssm. Both are setup with the setup script. The standby refuse both ssh and telnet connections. What have I forgotten?
GSS#show run
interface ethernet 0
   ip address #.#.#.# 255.255.255.0
   gss-communications
hostname GSS
ip default-gateway #.#.#.#
ip name-server 10.16.0.10
ip name-server 10.16.0.20
ssh enable
no ssh keys
no ssh protocol version 1
telnet enable
ftp enable
snmp-server trap-source ethernet 0
no cnr enable
drp
    no enable
terminal-length 23
exec-timeout 150
logging disk enable
logging disk priority Notifications
no logging host enable
logging host priority Warnings
logging facility local5
tacacs-server timeout 5
tacacs-server callerId-info-type hostname
tacacs-server keepalive-enable
GSS #
GSS#
GSS#show ssh
ssh is enabled
no ssh keys
GSS#show ssh
ssh is enabled
no ssh keys
GSS#show ssh
ssh is enabled
no ssh keys
GSS#show enable-passwd-status
GSS enable password is set.
admin password is the same on both boxes.
sokarlsson
Level 3
Level 3
Issue resolved. Somone had used the ip adress allocated for the standby GSS for something else.
