sticky by cookie not working
cricketbuff
Folks I have a situation where sticky by cookie is not working. When 2 nodes are UP it does not stick to the same node. When one node is up sticky is fine
See below my config
serverfarm host 24.8.1.10-80
probe TCP_21511
rserver test1 21511
inservice
rserver test2 21511
inservice
sticky http-cookie sticky_xwalk 24.8.1.10-80_STICKY
cookie insert browser-expire
replicate sticky
serverfarm 24.8.1.10-80
policy-map type loadbalance first-match 24.8.1.10-80_POLICY
class class-default
sticky-serverfarm 24.8.1.10-80_STICKY
what am i doing wrong?
huangedmc
Level 3
Level 3
The config looks correct - that's how we have ours set up.
When you look at the http header on a test workstation, do you actually see the cookie?
On the workstation we see the cookie but when 2 nodes are active in a serverfarm it does not stick to the same node.
I'm curious to know if the session made it into the sticky database...
Do you see it when you do "show sticky database static?"
Have you opened a TAC case?
Gilles Dufour
you may need to enable persistence rebalance with a parameter-map.
Gilles.
