Synchronization Script
lathian
Level 2
Level 2
I have trouble in synchronizing the configuration from Acitve to Backup CSS. I get the error message when I use this command:
CSS# Script play commit_redundancy "192.168.1.2"
APP session Ip Address '192.168.1.2' doesn't match Backup Ip Address
Note:192.168.1.2 is backupCSS.
2 CSS are 11050 and run the same version 5.0, use Active/Passive mode
Any advice would much appreciate it
pknoops
Level 7
Level 7
First make sure 'app' is running properly by doing a "show app session"
Make sure it does not show in the "init" state. The message you show above appears to have something to do with the app session.
Your 'master' css should have in it's config:
app session 192.168.1.2
app
Pete..
Thanks, it works perfectly now. I didn't configured App session before running the scripts.
