syslog issue in ACE
syjeon
Level 5
Level 5
I worked the ace on last night
I configured two context, 128 and 130
There are no problem in load-balancing server farm
but there are some issue in logging-server
I configured the logging buffer 6 to send the system message to syslog server
I didn't configured the resource-class related syslog buffer in admin context it's default unlimit
In the this morning.
I logged in the syslog server and saw the log to check syslog message from ace.
but there are no syslog message in my syslog server. In my think, the ace doesn't send syslog to syslog server. so I cleared log message in system buffer, and I received the log message from ace.
What happen in ACE? It it a possible bug? or Am I missed configured ?
Anyone who tell me why this situation happen?
Why I could receive the log after clear the log in ace?
I have to clear the log buffer to receive the syslog from ace?
the configuration like below
logging enable
logging standby
logging console 3
logging timestamp
logging trap 6
logging buffered 6
logging host 192.168.100.1 udp/514
the system image is "c6ace-t1k9-mz.3.0.0_A1_6_2a.bin"
Gilles Dufour
that's weird, but it might be because the syslog resource being all used already, it couldn't be allocated to your new context and the syslog process failed to start.
Once you cleared the buffer in Admin, you freed the syslog resources and the context could activate the syslog process.
We do recommend to set a max-limit to the syslog buffer to avoid consuming all the resources to allow creation of new contexts.
Gilles.
