TCL script to monitor MS shared folder?
zhichao
Is it possible to use TCL script to monitor Microsoft shared folders?
e.g. when the user remove one folder/file from the shared folder, the CSM should claim the server is down.
Thanks in advance!
Gilles Dufour
I don't have the answer but only suggestions.
I would suggest to capture a sniffer trace of a transaction you want to reproduce on the CSM.
Once you know exactly what is going on in the sniffer trace, we can use TCL on the CSM to replicate the same traffic.
Gilles.
thanks for the reply.
where can i get the help on TCl scripts? I am not familiar with it...
if you go to the CSM software download page you can find a xxxx.tcl file with many examples.
I would sugges to reuse one of them.
If you have specific questions, you can always post them here.
If you're not familiar with programming at all, you should ask help from a software person you may know.
Gilles.
