Technical Questions for ACE20-MOD-K9
Juan Ibañez
The ACE20-MOD-K9 have the functionality to do translations for ports, that is, for example, that a request received on port 443 is sent to the server on port 8443,and what would be the impact to the current context NAT configurations?
There is functionality to accommodate digital certificates balancers and not on the servers? and resource impact of this?
At this moment we work with persistence on a class C subnet mask, what would be the impact of CPU and memory if we apply the persistence on a host mask?
Have any impact on resources create a persistence settings for cookies?
Kanwaljeet Singh
Hi Juan,
I didn't get your first question.
Even if there is no NAT configured, if you configure rserver with port under serverfarm, when your request is received on VIP, ACE will forward the request back to rserver on port which have you specified in serverfarm. It has nothing to do with NAT. May be you can elaborate your question a bit.
SSL termination will take the load off of servers so that ACE does the SSL handshake and takes care of encryption and decryption processes. It has its impact on performance but depends upon the usage and capacity. I would recommend going through the performance guide for the same and it holds true for your other questions as well.
It depends how much ACE is already being used and how much you are planning to add. This is something you should plan and read ACE capacity/performance specifications and configure accordingly. I cannot give you any concrete numbers. You can check data sheets and other guides.
Kanwal
Hi Kanwal
What if to add persistence on a host whose address is contained in a persistence on a segment?
I add the settings that I have as an example:
Context Admin
resource-class STICK1
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 5.00 maximum equal-to-min
context RED-99
  description !!Red de Servicios 146.155.80.0/24
  allocate-interface vlan 99
  allocate-interface vlan 412
  member STICK1
Context ACE
sticky ip-netmask 255.255.255.0 address both STK_PORTAL_HTTP
  replicate sticky
  serverfarm PORTAL_HTTP
policy-map type loadbalance first-match PORTAL_HTTP
class class-default
     sticky-serverfarm STK_PORTAL_HTTP
class-map match-all L4_VIP_PORTAL_HTTP
   2 match virtual-address 146.155.80.150 tcp eq www
Juan
Hi Juan,
If you configure a network mask other than 255.255.255.255 (/32), the ACE module may populate the sticky entries only on one of its four/two network processors which may reduce the number of available sticky entries by 25/50 percent. This reduction in resources may cause problems when heavy sticky use occurs on the ACE module.
So it is better to use to 255.255.255.255. as the mask for optimal performance.
Kanwal
