Too many connections failed?
hugues.brunel
I use an ACE4710 pair in failover.
The WAN side is in VLAN 7 and the LAN side in VLAN 8. RealServers have private IP (192.168...) and Virtual IP of the service is a public internet address.
The ServerFarm is a Apache2 WebServer farm (only port 80).
The service is up from 2 days and here are the stats:
# sh stats conn
+------- Connection statistics ------------+
Total Connections Created : 86132
Total Connections Current : 485
Total Connections Destroyed: 46322
Total Connections Timed-out: 1867
Total Connections Failed : 37458
All the services seem to be fine from me, but where these "Connections Failed" could come from??
Thanks for any idea,
Hugues.
Gilles Dufour
Hugues,
always provide your software version when sending a question. It helps.
There was a known issue where connections closed with a RST where considered a failure even if the connection was successful.
G.
Thank you for your response :-)
Here is my software version:
Software
loader: Version 0.95
system: Version A3(1.0) [build 3.0(0)A3(1.0) adbuild_21:37:54-2008/08/10_/auto/adbu-rel4/rel_a3_1_0_throttle_buil/REL_3_0_0_A3_1_0]
system image file: (hd0,1)/c4710acemz.A3_1_0.bin
Device Manager version 1.1 (0) 20080805:0415
Where do I get information about this known issue?
H.
ok, your version should have the fix.
I was thinking about the following ddts :
CSCsh14278 - sh serverfarm failure conn incremented for successful connection
You will need to open a service request with the TAC so we can investigate further.
We will need a sniffer trace capture during the problem.
Start the trace, check the counter, and when there is a failure stop the trace.
G.
ok, I will take the time to make a capture tomorrow morning.
I will post the response.
Thx,
Hugues.
