Traffic interception using ACE instead wccp
c_simon
Community Member
I am probbing balancing the core WAEs with ACE. Most our servers are not balanced, their dft gw is not the ACE and we saw that when I am not using a VIP, the ACE does not do a nat and the traffic goes directly through 6500. The questions is: Can we use WAAS&ACE when the servers's company are not balanced by the ACE?
Thank in advanced.
Celeste
Gilles Dufour
Yes you can, but you need to guarantee that all traffic goes through ACE.
You can place the ACE module in transparent/bridge mode between your WAE's and their gateway.
Gilles.
Gilles.
Do you have an example with ACE where traffic going to Datacenter is intercepted by a PBR (that PBR sends traffic to the ACE) and traffic going to the branch is intercepted with another PBR(that PBR sends traffic to the ACE too)?
try this. I think it matches your requirement exactly
