Transparent mode with WCCP v2
songokudt5
Hi all.
I config my content engine 7305 with configurations:
CE(config)# wccp version 2
CE(config)# wccp router-list 1 10.10.10.1
CE(config)# wccp web-cache router-list-num 1
And with router:
Router(config)# ip wccp web-cache
Router(config)# interface Serial0
Router(config-if)# ip wccp web-cache redirect out
Address Router: 10.10.10.1/24
Address CE: 10.10.10.2 /24
Client1 connect internet with url: http://www.vnexpress.net
Client2 connect the same URL many times.
But when I use: sho statistic http saving
The hit is a little.(1 hit)
The miss is alot. (49 miss)
So I don't understand the ContentEngine work perfect or not????
Help me, plz
bwestbrook
You should check to see if your CE and router see each other.
CE "show wccp routers" - you should see the ID of your router you have configured.
Router "show ip wccp web-cache view"
If that doesn't work you can turn on debug
"debug ip wccp packets" and see the request/response sequence
.Jun 16 17:46:26: WCCP-PKT:S00: Received valid Here_I_Am packet from 10.1.1.1 w/rcv_id 00000844
.Jun 16 17:46:26: WCCP-PKT:S00: Sending I_See_You packet to 10.1.1.1 w/ rcv_id 00000845
