Upgrade steps for ACE 4710
osiristrading
Hi Everyone
We will be upgrading our ACE 4710s from A3(2.2) to A4(1.0). We have a pair in high availability mode. Has anyone here got any tips on how we can get a smooth upgrade without downtime? Is this even possible?
A
ddastoli
Of course it is possible to upgrade with no downtime!
However it is always recommended to schedule the upgrade in a maintenance window to minimize the impact in case of any issues.
You can normally find the documented procedure here for the upgrade:
http://cco/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/admin/guide/upgrade.html#wp1012243
I find in fact the best would be the following:
1. Upgrade the stand by module first.
2. Once reloaded, switchover to the standby and verify all services working correctly.
3.Upgrade the new stand by module.
4. Eventually switch over again to restore the active box as per the original configuration.
By doing this, if for some reason the first switchover at point 2. would not work, you can switch back to a safe scenario which you are sure to work.
Cheers,
Domenico.
