Urgent Help-Please Reply
rania20052006
Community Member
Dear All,
I have here in my company 25 Cisco Switch 3560 .
as i know, i will configure the Switch with the Basic configuration like Hostname & IP-Address - & Gateway.
My 2 question is :-
1- if i configure the switch with the Basic Configuration like IP-Address & Subnet mask & So on , where its saved on the Switch Exactly ?
2- instead of have the 25 Switch in-front of me , and assign each switch his configuration like IP-Address & all the Things, is there any way to copy the Configurations from the switch which i configured on the Text file & then on each switch i will modify the Text file which include the configuration for that switch ( New configuration ) & then apply to that switch ( the New one ) ?
if i can do like that , can i & HOW CAN I DO IT , PLEASE HELP ME BY WRITING THE COMMAND WHICH I NEED TO FOLLOW IT ?
Thanks .
Rania.
Gilles Dufour
Rania,
you're on the wrong group for this question.
You should go to "Network Infrastructure" -> "Lan switchig..."
The config is saved in NVRAM.
You can't access the NVRAM directly.
You could have the config in a file and TFTP it to the router/switch
The command is
'copy tftp startup-config'
Gilles.
