Using CSM for Network Management
mruuth
Level 3
Level 3
I'm thinking about using the probefacility in CSM to probe almost all servers, including normally notloadbalanced servers, because then I have the possibility to send users to a sorryserver when something is wrong. Questin: How many probes can I run against how many servers. Which IPX-CPU i used for probes? Ihave standard probes and TCL-probes.
Mats
Gilles Dufour
no IPX are used for probes. It's the PPC [main CPU] that handles them.
You can have quite a huge amount of probes.
But it depends on what type of probes and the frequency.
Do a 'sho mod csm X tech probe' and you should see the limitations at the top.
Gilles.
Thanks for information.
When I did the command I saw statistics. How do I know which probe belongs to which statistics?
Below is a extract from information.
This suspect has connected unsuccessfully 838 times
This suspect has tried to connect 59761 times
This suspect has succeded 0 times
This suspect has received 0 replies
This suspect has connected unsuccessfully 847 times
This suspect has tried to connect 200923 times
This suspect has succeded 200810 times
This suspect has received 200834 replies
Regard
Mats
you need to type the command
'sho mod csm X probe real' and you'll get the information that you need.
Thanks for your rating.
Gilles.
