url based load balancing
lindacitron
Community Member
I have my load balancing configured as follows:
URLs
/xxx/1 and /xxx/2 route to server1
URLs
/xxx/3 and /xxx/4 route to server2
This is working fine when the client application opens and closes the tcp connection for each http packet. For performance reasons we would prefer to open one connection and keep it open. When I try to do that I see that the first few packet that are all for server1 succeed, but the first one for server2 fails, and all subsequent packets on that connection fail.
Is there a way to configure the CSS to do what I want to do?
Linda
9 Replies 9
Gilles Dufour
Linda,
in your content rule, use the command 'no persistent' and in global config mode, use the command 'persistence reset remap' to have the client redirected to the new server transparently.
You should also increase the default idle timeout.
The reason is that a persistent connection is very often idled and the CSS can't remapped idle connection.
To increase the timeout use 'flow-timeout-multiplier' if you have a CSS 11500 otherwise use the command 'flow port1 80 timeout 600'
Gilles.
Thanks Gilles, It now load balances between the two servers, but when a packet gets routed to server2 server1 gets a ECONNRESET (connection reset by peer). The next packet to server1 opens a new connection. But once that connection is open the remaining packets whether to server1 or server2, go to server1..
I.E. if my configured rules are
/1 /2 route to server1
/3 /3 route to server1
This is what happens..
/1 goes to server1
/2 goes to server1
/3 goes to server2
server1's socket gets closed
/1 goes to server1 (new socket)
/3 goes to server1
What am I doing wrong?
could you please attach a 'show run' so I can see what's wrong.
Gilles.
Thanks, Here it is..
User Access Verification
Username:cisco
Password:
CSS11050# show run
!Generated on 01/01/2079 00:00:51
!Active version: ap0610405
configure
!*************************** GLOBAL ***************************
username cisco des-password xxxx
no restrict web-mgmt
no restrict xml
dns primary 10.63.3.60
dns secondary 10.63.2.32
dns suffix il.nds.com
host eshames-lin 10.63.60.191
host lcitron-lin 10.63.61.38
ip route 0.0.0.0 0.0.0.0 10.63.61.254 1
!************************* INTERFACE *************************
interface e1
bridge port-fast enable
interface e2
interface e3
bridge vlan 61
interface e4
bridge vlan 61
interface e5
bridge vlan 61
interface e6
bridge vlan 61
interface e8
bridge vlan 2
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.63.31.241 255.255.254.0
circuit VLAN61
ip address 10.63.61.245 255.255.254.0
circuit VLAN2
!************************** SERVICE **************************
service Atnds
ip address 10.63.5.12
active
service Citron
ip address 10.63.61.38
active
service Gershon
ip address 10.63.31.228
active
service Shames
ip address 10.63.60.191
active
!**************************** URQL ****************************
urql Linda-urls
description "Linda Web Server"
url 1
url 2
url 3
url 4
url 5
url 6
url 7
url 8
url 1 url "/bin/0/IB"
url 2 url "/bin/1/IB"
url 3 url "/bin/2/IB"
url 4 url "/bin/3/IB"
url 5 url "/bin/4/IB"
url 6 url "/bin/5/IB"
url 7 url "/bin/6/IB"
url 8 url "/bin/7/IB"
active
urql Shames-urls
description "Shames Web Server"
url 1
url 2
url 3
url 4
url 5
url 6
url 7
url 8
url 1 url "/bin/8/IB"
url 2 url "/bin/9/IB"
url 3 url "/bin/10/IB"
url 4 url "/bin/11/IB"
url 5 url "/bin/12/IB"
url 6 url "/bin/13/IB"
url 7 url "/bin/14/IB"
url 8 url "/bin/15/IB"
active
!*************************** OWNER ***************************
owner NDS.COM
content L3
vip-ping-response local-remote
vip address 10.63.31.229
protocol tcp
port 80
url "/*"
add service Gershon
active
content L5-Linda
vip address 10.63.61.244
add service Citron
protocol tcp
port 7001
url urql Linda-urls
no persistent
active
content L5-Shames
add service Shames
protocol tcp
port 7001
url urql Shames-urls
no persistent
active
CSS11050#
The config looks good.
The disconnect that you see on server1 is normal once the connection is remapped to server2.
Could you capture a sniffer trace of this issue ?
On client side and server side.
Gilles.
Hi Gilles,
I think I got a better handle on the problem..
My server's operation: - reads a packet from the tcp port,
- sends back a response. (in this case as you will see in the tcpdump its the server name)
When my client does the following:
- sends a packet
- reads the response.
Everything works fine...
When my client doesn't always read the response, things start not working.
The following traces are for the following scenario:
Client:
SendandRead(1)
SendandRead(2)
SendandRead(8)
SendandRead(9)
Send(3)
Send(10)
Send(4)
Send(4)
In the trace that is attached, the server never even gets 3. But sometimes it does. (when sniffing is on it never gets it!)
BTW I know that normal operation is that clients should always read the responses, but clients don't always work right...
Linda
Hi Gilles,
Is it true that with http messages the css always expects the client to read the response before sending something else on the same connection, otherwise the css gets confused?
Please confirm.
Linda
Linda,
looks like your client is doing pipelining.
It is sending request without waiting for the response.
This is not supported by any loadbalancer including the CSS.
Go into your browser setup and disable HTTP pipelining.
Gilles.
My client is doing pipeling, I wrote the client. If the CSS can't handle pipling it seems to me that it also can't handle things like a response getting lost, or takes so long to get back to the client that the read times out.
Responses can't really get lost because its tcp, but
would the correct thing to do then on a read timeing is to close the connection and open another one?
