URL Filtering Cache Engine 510
antonios
Level 3
Level 3
Is it possible to get a Cache 510 to pass URL requests to a SurfControl server. I see that N2H2,Websense and Smartfilter are supported and was wondering if it could work to a SurfControl server
mark.duffy
Level 3
Level 3
The content engines only support N2H2, Websense and Smartfilter by direct support (ie they are enabled via the command line), your only options are to use a static URL deny/allow file on the CE or use an upstream proxy (non CE) with Surf Control at the moment, I don't know of any plans to add other filtering products, Websense is the new kid on the block for the CE and is quite nice.
regards
Mark
HI,
Mark is absolutely right. You are having the three mentioned methoded and the made by hand one on the box. BUT you can add any other filtering device if it can be accessed via ICAP. Since ACNS 5.1 ICAPv1.0 is supported (see http://www.cisco.com/en/US/products/sw/conntsw/ps491/products_data_sheet09186a00801d8412.html)
Cheers,
joerg
