URL redirection by using Cisco CSS LB
Gajendra R'
Level 2
Level 2
Hi ,
Can we redirect the URL which client from outside type to the original domain URL.
Let me explain (as there are 10 url are working on two server which is under two content port 80, and 443)
User sitting outside type the url like :- http://abc.com?xyz=1
this url should be redirect to https://abc.com
7 Replies 7
InayathUlla Sharieff
Here is the redirect config link:
http://www.cisco.com/c/en/us/support/docs/application-networking-services/css-11000-series-content-services-switches/41840-redirects-config.html
there are different ways to configure redirect on the CSS.
Here is a link explaining all of them
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801de8d6.shtml
You need to make use of the command 'domain' in order t o preserve the path.
Inayath
*plz rate all usefull posts.
Hi Inayath,
Thanks for your email.
  content Bapu-443
    add service 192.168.202.148-web1-451
    vip address 192.168.202.202
    port 443
    protocol tcp
    no persistent
    balance leastconn
    advanced-balance sticky-srcip
    active
  content Babu-80
    add service 192.168.202.148-cu-81
    add service 192.168.202.149-cu-81
    port 80
    protocol tcp
    url "/*"
    no persistent
    balance leastconn
    active
As i have tried to configure DQL as well as the Redirect string for URL redirection from http://abc.com?xym=1 to https://abc.com
however not got succeeded
If possible please suggest the configurations.
For configuring redirection, you need to configure a service which doesn't exist in your network and you need to add that service as type "redirect" and define the domain/redirect-string to which the clients would be redirected. The above configuration you have pasted is for loadbalancing and not redirection.
************************** SERVICE **************************
service Redirect
     ip address 2.2.2.2
     keepalive type none--->Keep it none to make the service active.
     type redirect
     no prepend-http--->This needs to be added if redirection is from http to https.
     redirect-string https://abc.com
     active
*************************** OWNER ***************************
    owner Redirect-test
     content Redirect-Rule
      port 80
      protocol TCP
      vip address 206.25.90.84
      add service Redirect
      URL "/*"
      active
The VIP address must be equivalent to the IP address that the user will come on. In your case it would be http://abc.com.
Kanwal
Note: Please mark answers if they helpful.
Hi Kanwal,
 Thanks for your suggestion.
Let me try this and see...
Moreover would like to ask you that; should i create new service for redirect and give the ip address same as its given to service 192.168.202.148-cu-81 and then add this service to the content..........   content Babu-80.
No. You need to create a service for redirect and use an IP which doesn't exist. The CSS itself redirects the request. Use keepalive none so that service stays up.
Kanwal
Note: Please mark answers if  they are helpful.
Hi Kanwal,
 I have tried as per your suggestion; unfortunately dint work.
as i have created a new service called Redirect and then assign that service under the existing Content. as follow.
service Redirect
     ip address 2.2.2.2
     keepalive type none
     type redirect
     no prepend-http
     active
  content Babu-80
    port 80
    protocol tcp
    url "/*"
    no persistent
    balance leastconn
    active
Could you please tell me, whether am missing something
Gajendra
Hi Gajendra,
You need to create another content rule under the owner. Adding under the same content rule is not correct. Something like the below example.
!************************** SERVICE **************************
service Redirect
  ip address 2.2.2.2
  keepalive type none
  type redirect
  no prepend-http
  Redirect-string https://www.cisco.com
  active
service regular-server1
  ip address 10.2.3.4
  active
service regular-server2
  ip address 10.2.3.5
  active
!*************************** OWNER ***************************
owner CSS-Team
  content Redirect
    protocol tcp
    port 80
    url "/*"
    active
  content ssl-rule
    protocol tcp
    port 443
    add service regular-server1
    add service regular-server2
    active
Let me know if you have any questions.
Kanwal
