Using ACE's XML interface
Disizme95
Community Member
I'm encountering troubles with ACE's XML interface:
-trying to perform a "show running config" I did the following via curl
curl "http://www:[password]@[ACE_IP_ADRESS]/bin/xml_agent" -k  -d "xml_cmd=<request_xml context-name=\"Admin\"><show_running-config/></request_xml>"
But ACE replies that the context name is invalid!! And when I do the same thing without specifying a context name it works and display the running config for Admin context!
The problem is that I need to do this show command in other contexts. I think specifying a context name is similar to executing a "changeto" command from the CLI so I have to do it...
Thank you for helping
litrenta
Level 8
Level 8
To use context name the tag is ctx-name so if I want to get running config for a context named sam you would use:
xml_cmd=\r\n
\r\n
\r\n
\r\n
5 Replies 5
litrenta
Level 8
Level 8
xml_cmd=\r\n
\r\n
\r\n
\r\n
Thank you for the answer. In fact it was because I didn't have the Admin role and because the IP address I used for the request was the IP of a specified context so I couldn't display the show run of the Admin context...
Well it works grat now
AlexandrKry
Level 2
Level 2
Hello guys,
I'm trying to accomplish something different, but it fits the topic.
I want to get the show resource allocation command output via XML interface.
Here's the xml_cmd that I tried:
xml_cmd=
But I'm getting the following error:
command - not supported by xml interface
What is the correct xml_cmd I should send to ACE to get the output of show resource allocation?
I always use raw request i.e:
xml_cmd=xml-show on\r\n
show resource usage\r\n
\r\n
For the benefit for all, there is a document posted which talks about XML request to ACE mod/Appliance. It also convers few tricks and examples
https://supportforums.cisco.com/docs/DOC-17849
